Ather Konarc Charging Time: How Long Does It Take to Charge?
4 Nov, 2026
Kritanjay Sharma
The Ather Konarc redefines electric scooter charging by offering flexible home charging setups alongside high-speed public grid access . Built on Ather's new EL platform, the Konarc lineup integrates an onboard charger and introduces Combined Charging technology to cut down home charging times.
How Long Does the Ather Konarc Take to Charge?
The Ather Konarc takes 4-8 hours to achieve 0-80% charge with a 450W charger. Ather Konarc offers multiple charging options ranging from standard home charging to ultra-fast public charging solutions. The charging time differs according to the charging setup and battery capacity.
  • Standard 450W Onboard Charger: Takes 4 to 8 hours depending on your battery size for a 0–80% charge.
  • 900W Combined Charging Setup: Reduces 0–80% charging time down to 2 to 4 hours depending on your battery size.
  • Public Fast Charging: Adds up to 30 km of range in 10 minutes across 6,000+ public fast chargers.
Ather Konarc Home Charging Time
Ather Konarc offers multiple home charging options depending on your setup and requirements:
  • Standard 450W Onboard Charger: Takes 4 to 8 hours to reach 80% charge across variants using a lightweight, brick-less cable plugged into any standard 5A socket.
  • 900W Combined Charging: Reduces home charging time to 2 to 4 hours (0–80%) by combining the 450W onboard charger with an additional 450W offboard unit.
Ather Konarc 0–80% Charging Time
The Ather Konarc achieves a 0–80% state of charge in 2 hours to 4 hours with Combined Charging (900W), compared to 4 hours to 8 hours with the standard 450W onboard charger.
Variant
Battery Capacity
Standard 450W (0–80%)
Combined Charging 900W (0–80%)
Konarc S 100km
2.1 kWh
4h 00m
2h 00m
Konarc S 125km
2.7 kWh
4h 30m
2h 25m
Konarc S 161km
3.5 kWh
5h 40m
3h 10m
Konarc S 200km
4.7 kWh
8h 00m
4h 00m
Konarc Z 125km
2.5 kWh
4h 30m
2h 25m
Konarc Z 161km
3.5 kWh
5h 40m
3h 10m
Does Charging Speed Vary Between Konarc Variants?
Yes, charging speed and duration vary across Ather Konarc variants due to differences in battery pack capacity and charging configurations. While every Konarc variant comes equipped with the default 450W onboard charger, battery sizes range from 2.1 kWh up to 4.7 kWh .
  • Home Charging Duration: Home Charging takes about 2 - 8 hours depending on the battery pack size.
  • Combined Charger Availability: Combined Charging as a capability is built into all Konarc models, allowing any variant to achieve faster charging speeds. However, the offboard unit with the additional 450W brick comes bundled out-of-the-box only with select variants, while being offered as an optional upgrade or add-on accessory for the rest of the lineup
  • Public Fast Charging Speeds: Most Konarc models gain up to 15 km in 10 minutes at an Ather electric scooter charging station, whereas the flagship Z 161km gains up to 30 km in 10 minutes .
Ather Konarc Combined Charging Explained
Ather Konarc Combined Charging pairs an internal 450W onboard charger with an external 450W offboard charger to deliver 900W of total charging power. This innovative architecture reduces home charging duration by up to 50% without adding excessive weight to the scooter chassis, but instead keeping that as an optional offboard brick .
  • Combine them modularly: Riders can use the 450W onboard charger alone for maximum portability or stack the additional 450W offboard unit for double the charging speed .
  • Distribute the bulk: Balances vehicle weight by keeping a reasonably sized brick onboard while allowing riders to add offboard capacity as needed .
  • Superior LECCS Connector Standard: Utilizes the Bureau of Indian Standards (BIS) approved Light Electric Combined Charging System connector, integrating AC and DC pins into a single port .
The Ather Konarc provides a versatile charging setup designed for daily city commutes and spontaneous rides . By combining a built-in onboard charger with optional 900W Combined Charging and extensive Ather Grid public fast-charging coverage, the Konarc ensures you spend more time on the road and less time plugged into a socket.
Ather Konarc
