Electric Scooter Safety Checklist Before Every Ride: Ather 450 Series
Anand Kumar
6 min read
Your Ather 450 delivers a performance-oriented, hassle-free ride. When navigating the urban landscape, many commuters analyze electric scooter vs bike safety to choose the most reliable vehicle. A quick daily inspection improves safety, maintains peak performance, and prevents unexpected issues. Following are a few check points before you start your ride.
Tyre Pressure and Brake Check
Your tyres and brakes are critical for safety and ride comfort. A quick inspection helps identify potential issues early.
Check Tyre Pressure
Maintaining the recommended tyre pressure helps ensure:
  • Optimal energy efficiency and range
  • Improved ride comfort
  • Reduced tyre wear
  • Better stability and handling
  • Consistent braking performance
Since visual inspections can be misleading, regular commuters should use a tyre pressure gauge or TPMS accessory to monitor tyre health accurately.
Inspect Tyre Condition
Before every ride, check for:
  • Cuts or cracks on the sidewall
  • Embedded nails, stones, or sharp objects
  • Uneven tread wear
  • Bulges or deformities on tyre and electric scooter wheel rim
Healthy tyre tread is especially important during wet weather, where it helps maintain grip and stability.
Test the Brakes
The Ather 450 series delivers confident braking performance, but a quick check is worthwhile.
Before riding:
  • Squeeze both brake levers and ensure they feel firm.
  • Check for unusual noises or vibrations.
  • Confirm smooth and predictable braking response.
If braking performance feels different, schedule an inspection before continuing regular use. Remember that stopping a vehicle traveling near its electric scooter maximum speed requires optimal braking conditions, so never ignore spongy brakes.
Battery and Dashboard Alerts
Riding a connected electric scooter gives you access to real-time vehicle information.
Verify Battery Charge
Before starting your ride:
  • Check the battery state of charge.
  • Ensure you have sufficient range for your planned journey.
Starting a ride with adequate charge helps avoid range anxiety and charging interruptions.
Review Dashboard Notifications
The Ather dashboard continuously monitors key vehicle systems and provides important alerts. It runs comprehensive diagnostics to check the state of the electric scooter motor and battery system automatically.
Before every ride, take a quick glance for:
  • Warning lights
  • Service reminders
  • Connectivity notifications
  • Charging-related alerts
  • Battery or system diagnostic messages
Addressing notifications early helps prevent larger issues and ensures peak performance.
Lights and Indicators Inspection
Ensuring all lights function correctly improves your visibility and helps other road users understand your intentions.
Check the Headlight
Verify that:
  • The headlight switches on properly.
  • Brightness is consistent.
  • The lens is clean and unobstructed.
Verify Tail Lamp and Brake Light Operation
Ensure:
  • The tail lamp is functioning normally.
  • The brake light illuminates when either brake lever is applied.
Test the Indicators
Check both left and right turn indicators before every ride. Working indicators help communicate lane changes and turns clearly.
Don't Forget the Horn
The horn is an essential safety feature in busy urban environments.
Before setting off:
  • Test the horn.
  • Ensure the sound is clear and audible.
  • Address any weak or intermittent operation.
Monsoon Visibility Check
During the rainy season, visibility can change rapidly due to rain and fogging. Make sure all lighting elements are functioning correctly and keep lenses clean for maximum effectiveness.
Helmet and Safety Gear Essentials
Protective gear is the most important safety feature on any scooter.
Wear a Certified Helmet
Always wear a properly fitted helmet and ensure the chin strap is securely fastened.
Before every ride:
  • Inspect the helmet for cracks or visible damage.
  • Check visor cleanliness and visibility.
  • Replace helmets that have experienced a significant impact.
Additional Riding Gear
For everyday commuting and longer rides, consider:
  • Riding gloves
  • Closed-toe footwear
  • Protective riding jackets
  • Reflective gear for improved visibility at night or during rain
Proper riding gear significantly reduces injury risk while improving comfort.
Adjust Mirrors Before Riding
Mirrors can shift over time due to vibrations or accidental contact.
Before every ride:
  • Adjust mirrors for a clear rearward view.
  • Ensure mirrors are securely mounted.
  • Clean mirror surfaces if visibility is reduced.
Good mirror positioning reduces blind spots and improves situational awareness.
Summer Safety Tips
Indian summers demand extra care. A few simple precautions can help improve comfort and maintain vehicle performance.
Park in the Shade Whenever Possible
Direct sunlight can significantly increase seat temperatures and heat up vehicle components.
Whenever possible:
  • Use covered parking.
  • Park in shaded areas.
  • Use a protective scooter cover for extended outdoor parking.
Protect Battery Health
While the Ather battery management system is designed to manage operating conditions effectively, avoiding excessive heat exposure is always beneficial. Overheating can also affect the electric scooter motor efficiency over time.
Good practices include:
  • Avoiding prolonged parking in direct sunlight.
  • Allowing the scooter to cool naturally after extended heat exposure.
  • Charging in a well-ventilated area.
  • Using only approved charging equipment.
Stay Hydrated
For longer rides:
  • Carry drinking water.
  • Wear breathable riding gear.
  • Take breaks during peak afternoon temperatures.
Ride Defensively
Summer glare, dust, and heat haze can affect visibility. Regardless of the open road, strictly observing the appropriate electric scooter speed limit is vital. Pushing the vehicle to its absolute electric scooter maximum speed in intense heat can compromise both performance and vehicle stability. Maintain safe following distances and stay alert to changing road conditions.
Monsoon Safety Tips
Rain introduces challenges such as slippery roads, reduced visibility, and longer braking distances. Extra precautions make your monsoon rides safer.
Check Tyre Tread More Frequently
Tyre grip becomes even more important during wet conditions.
Before riding:
  • Inspect tread depth for wear.
  • Ensure tyres are properly inflated.
  • Replace tyres showing significant wear.
Good tread depth helps improve water evacuation and wet-weather grip.
Test Brakes Before Entering Traffic
Wet roads increase stopping distances.
At the start of your ride:
  • Perform a gentle brake test in a safe area.
  • Confirm smooth braking response.
  • Leave greater following distances than usual.
  • Avoid abrupt braking inputs, especially on slippery surfaces.
Ensure Maximum Visibility
Before riding in the rain:
  • Verify headlights, tail lamps, brake lights, and indicators are working.
  • Keep your helmet visor clean.
  • Wipe mirrors if visibility is reduced.
Avoid Deep Water and Waterlogged Roads
Standing water can hide potholes, debris, and road damage that could severely impact an electric scooter wheel or suspension component.
Whenever possible:
  • Choose routes with better drainage.
  • Avoid deep water crossings.
  • Ride slowly and steadily through unavoidable waterlogged sections.
Ride Smoothly and Predictably
During wet conditions:
  • Accelerate progressively.
  • Brake gently and early.
  • Avoid sudden steering inputs.
  • Maintain larger safety gaps from surrounding vehicles.
Smooth riding helps maximise available tyre grip. Furthermore, adhering to a conservative electric scooter speed limit gives you much more reaction time on slick roads.
Wear Appropriate Rain Gear
Consider using:
  • A quality rain suit
  • Waterproof gloves
  • Anti-fog visor solutions
  • Reflective riding gear
A safe ride starts before you twist the throttle. By checking tyre pressure, tyre condition, brakes, battery charge, dashboard alerts, lights, indicators, mirrors, and safety gear, you can significantly reduce the chances of unexpected issues.
Ultimately, when discussing electric scooter vs bike safety, routine preparation is often the deciding factor. Making this inspection part of your daily riding routine helps ensure your Ather 450 series scooter continues to deliver performance, efficiency, and reliability. Just a few minutes of preparation before every ride can help you ride safer, ride smarter, and enjoy every journey with confidence.
