      Things to Know About Park Assist in Electric Scooters
      27 Aug, 2026
      Anupam Sharma
      6 min read
      Every ride begins and ends in a parking spot. Navigating these spaces sets the tone for your daily commute. In crowded areas, parking spots can be tightly packed, leaving almost no room to smoothly pull out your scooter. Factor in parking on a slope or getting stuck right in front of a speed breaker, and the physical effort quickly adds up.
      At Ather, we saw these common problems faced by regular commuters and thought of solving them through intelligent engineering and tech. Engineering for utility means equipping our riders with intelligent, practical electric scooters to make your daily commute entirely effortless from the day you ride on your Ather. Our park assist technology is designed to eliminate the physical hassle.
      Here is a breakdown of the engineering and utility behind this essential feature.
      What is Parking Assist in Electric Scooters?
      Park assist lets the scooter move in tight spots, Instead of straining your legs to paddle the vehicle in and out of a spot, the motor gently rolls it forward or backward for you.
      Guiding a two-wheeler through a packed parking lot or a tight basement can be tricky. An advanced parking system, which is exactly what the park assist feature on Ather electric scooters is, takes away the physical strain of getting into or out of small spaces.
      • Low-Speed Aid: It is a dedicated feature that supports the rider during slow movements.
      • Motor-Powered Mobility: Instead of manually pulling and pushing the scooter with your hands and feet, you use the scooter’s own motor to move.
      • Throttle control: The scooter can be moved backwards and forwards by using the throttle in a special mode, functioning as either park assist forward or park assist reverse.
      How does Parking Assist work in Electric Scooters?
      Understanding exactly how does parking assist work reveals the seamless connection between Ather electric scooter hardware and software.
      • Torque Generation: In Ather electric scooter like the 450 and Rizta, park assist works by using the electric motor to provide torque to the wheel.
      • Energy Source: The energy required for this operation is taken straight from the battery.
        Command Center: The motor controller is strictly responsible for deciding how much torque to provide based on your input.
      • Algorithmic Precision: The motor controller features a dedicated processor. Software algorithms run on this processor to ensure that enough torque is provided to move the vehicle while the speed is safely limited.
      Benefits of Parking Assist for Electric Scooters
      Navigating the challenges of electric scooter parking is simplified with this feature in the Ather 450 series and the Rizta. We modelled this experience on the reverse function in cars; just as a car glides back effortlessly with a simple gear shift, we wanted that same level of ease for two-wheelers.
      Challenge
      The Park Assist Solution
      Space Constraints
      Without park assist, you often have to use your entire body's strength to pull the vehicle back. The motor provides precision movement instead of testing the limits of your calves.
      Steep Inclines
      Moving manually is especially hard if the scooter is parked on a slope. Park assist provides the necessary mechanical push/pull.
      Rider Fatigue
      Park assist heavily reduces the manual effort required by the user, reserving your energy for the actual commute.
      Parking Assist Features of Ather Electric Scooters
      Our implementation of advanced parking assist is engineered for absolute stability and instant response. When you engage this feature on an Ather electric scooter, you are utilizing a highly tuned system.
      • Efficient Power Draw: The energy required for this maneuver is taken directly from the battery pack with high efficiency.
      • Intelligent Controller: Our motor controller is responsible for deciding precisely how much torque to provide to keep the movement smooth. We also ensure safe operation of the motor and prevent overheating.
      • Software-Backed Safety: The motor controller houses a processor where our custom software algorithms ensure that enough torque is provided to overcome obstacles or slopes, while the top speed remains strictly limited for rider safety.
      Your daily commute should be a seamless experience. By utilizing intelligent motor control and advanced software algorithms in Ather electric scooters, like the 450 and Rizta, we ensure that getting in and out of a parking spot is as smooth as the ride itself. Ather’s park assist technology is pure utility in action, designed specifically to make daily commute easier.
      Comfort & Convenience
      Design
      Ride Experience
