      Electric Scooter Charging: Home vs Public – Which Should You Choose?
      23 Sep, 2026
      Sanya Sawlani
      The choice between home and public charging isn't about 'which is better,' but about having options that eliminate range anxiety. The most optimum method is to simply build a habit of charging at home, just as you do with your smartphones and laptops. Public charging at Ather Grid is available for those times when you've commuted more than planned and need a quick top-up to comfortably reach home and charge properly. We recommend home charging for everyday usage and public charging is available for you in case of those times that you have missed charging or have a longer commute.
      How to charge an electric scooter at home?
      The best way to understand how to charge electric scooter battery at home is simple: plug it in when you’re done for the day.
      We’ve designed our home charging ecosystem—specifically the Ather Duo Charger, For your flexibility, which you can fix at your parking spot with the wall mount or carry it along in your boot. It’s a fixed charger when you are at home and a portable one when you are not. Works as a portable or fixed charger. Fits into any 5A or 6A 3-pin socket when you need it and into the boot when you don’t.
      The most clear advantage you get is charging at different parking setups without changing your routine.
      The Setup: You plug the Ather Duo into any standard 5A or 6A socket.
      1. The Routine: Park, plug in, and walk away.
      2. The Efficiency: Most owners find that in a single charge they get ~110 km of range, which can cover up to 4 days of commute (based on an average ~20km commute every day). This means you only really need to plug in twice a week!
      3. The Intelligence: With Optimized Charging, you can set your scooter to stop at 80% for daily commutes, keeping your battery healthy for years.
      How to charge an electric scooter at Public EV Charging Stations?
      Ather Grid—is designed for speed and convenience when you are on the move. We know that life doesn't always happen within the range, which is why the Ather Grid is strategically located so you can charge conveniently at malls, cafes, and tech parks while you go about your day.
      1. Locate: Open your Ather App to find the nearest Grid Point.
      2. Speed: The Grid is built for speed, adding up to 1.5 km of range per minute.
      3. Range: In just 10-15 minutes, you can get up to 30 km of range.
      Electric Scooter Charging Costs: Home vs. Public Charging
      Home ChargingPublic Charging (Ather Grid)
      Residential electricity billPremium "on-the-go" service
      Consumption: 3 to 4 units per full chargeFee Structure: Time-based fee
      Cost: ₹25 to ₹35 per full charge (at ₹7-8/unit)Cost: Typically ₹1.2 per minute + GST
      Running Cost: ₹0.30 to ₹0.40 per kmRunning cost: ₹0.3 per km
      Tips for charging an electric scooter at Home vs. in Public Charging Stations
      For Home Charging:
      • Ensure your charging point is dry and  in a clean space without any risk of rat infestation
      • Check Your Earthing: Ensure your home socket is properly earthed for maximum safety.
      For Public Charging (Ather Grid):
      • Use the Grid to get enough range to reach your next destination or home.
      • Once you have the range you need, move your scooter so another rider can use the strategically located charger.
      So, which one is better? The beauty of the Ather ecosystem is that there is no wrong answer. Ather provides options which suit the rider, allowing you to choose based on your lifestyle. If you prefer the "fill it and forget it" lifestyle, home charging gives you enough range for nearly half a week of commuting for the price of a vada pav. If you are an urban explorer who is always on the move, the Ather Grid ensures you are never far from a fast-charging point. Whether you value the ultimate savings of home charging or the rapid speed of the Grid, we’ve built the infrastructure to make sure your ride is always powered up.
      Savings
