      How to Increase the Speed of Your Electric Scooter?
      16 Jul, 2026
      Saikiran T Nuli
      You can maximize your electric scooter's top speed by switching to high-performance ride modes on advanced performance scooter models from Ather (like Warp or Warp+), maintaining optimal tire pressure to eliminate mechanical drag, and keeping your battery charged above 50% to ensure peak voltage delivery.
      Implementing these steps allows modern performance scooters to completely shatter the old myth that EVs are slow. For perspective, early low-speed imports capped out at 25 km/h, but a well-optimized Ather 450X easily hits 90 km/h, while the track-ready Ather 450 Apex rockets to a top speed of 100 km/h.
      Key Factors That Affect Electric Scooter Speed
      To increase your scooter's speed, you must first understand the primary factors that hold it back:
      • Thermal Management and Derating: High-speed riding generates intense motor heat. While premium scooters feature advanced thermal dissipation to maintain pace, continuous stop-and-go riding or harsh acceleration can trigger "derating"—a protective feature that temporarily caps top speed to safeguard the motor from heat damage.
      • Tire Pressure and Mechanical Drag: Low tire pressure drastically increases rolling resistance, acting like a constant brake on your momentum. Maintaining the optimal PSI reduces this friction, allowing the motor to propel the scooter to its maximum velocity with minimal effort.
      Ways to Increase the Speed of Your Electric Scooter
      The internet is full of "hacks" on how to remove the speed limiter on electric scooter. Our advice? Don’t risk it. Unverified electric scooter modifications can compromise the battery’s chemistry and instantly void your warranty.
      If you want more speed, do it the Ather way:
      • Master the Riding Modes: Ather precision-engineers multiple riding modes to optimize range, acceleration, and top speeds. Users can switch modes to attain higher speeds and better acceleration with a small compromise on range.
      • Engage Warp+ Mode: This ultimate e scooter upgrade is pre-installed in the Ather 450 Apex. Warp+ optimizes the controller to unleash the motor’s full potential, delivering a 0-40 km/h burst in just 2.9 seconds.
      • Maintain Constant Speed for High Efficiency: Motor efficiency is highest when you maintain a constant speed. The 450 Apex features Infinite cruise, enabling users to maintain constant speeds from 10kmph to 90kmph without getting kicked out of cruise by hills, braking, or magic twist.
      Maintenance Tips to Improve E-Scooter Speed
      Reliable speed is a result of care. Follow these essential electric scooter maintenance tips
      • Maintain Ideal Tire Pressure: Check your tires weekly. Running at the recommended PSI reduces friction and allows the motor to reach its peak RPM effortlessly.
      • Battery Health: Don’t let your battery sit at 0% or 100% for extended periods. A healthy battery delivers higher voltage, which directly translates to better speed.
      • Regular Service Visits: Regular service visits at an Ather service station ensure that the mid-drive motor alignment, firmware health, and mechanical clearances are all optimized. We are the masters of our product, and our technicians ensure your ather electric scooter is always ready to own the road.
      • Belt Tension and Alignment: Unlike the hub motors in cheap imports, Ather uses a mid-drive motor with a belt drive. Ensure your belt is clean and tensioned correctly to ensure every bit of torque reaches the rear wheel without loss.
      • Brake Caliper Check: Ensure your disc brakes aren't "dragging." A slightly misaligned brake pad can create friction that silently kills your top speed.
      • Let the Motor Cool: Give your scooter a moment. While our thermal management takes care of everything, letting the motor cool after an intense sprint prevents the software from derating (slowing down) to protect the hardware. A cool motor is a fast motor.
      The reality is that the real secret to sustained speed lies in superior engineering, intelligent software, and disciplined maintenance.At Ather, we have the 450 apex, that gives you the speed and thrill. Keep your software updated, your tires pumped, and your spirit adventurous. The road is yours, fast, silent, and uncompromising.
      Design
